delay header
delay header
745 次查看
vahidnoori
hiii.
i seek to header file of Delay for k20d50. help me plz:smileycool:
标记 (2)
4 回复数
538 次查看
vahidnoori
hi ping.
this function( LPLD_LPTMR_DelayMs(uint16 period_ms)) did not work correctly . when program go to this function stop and do not rich to the next line after delay function.for example in this:
main{
LPLD_LPTMR_DelayMs(500);
code A;
code A dose not performed.
why ?:smileycry:
538 次查看
jeremyzhou
Hi Vahid,
Sorry for late reply, I suggest that you'd better debugger the project by IDE software to figure out the exactly problem.
I'm looking forward your reply.
Ping
538 次查看
jeremyzhou
Hi Vahid,
Do you want to a delay function for K20D50? If it's right, you can use LPMR to make it out as below show .
Ping
void LPLD_LPTMR_DelayMs(uint16 period_ms)
  if(!period_ms)
    return;
  SIM_SCGC5|=SIM_SCGC5_LPTIMER_MASK;
  LPTMR0_CMR = period_ms;
  LPTMR0_PSR = LPTMR_PSR_PCS(1)|LPTMR_PSR_PBYP_MASK;
  LPTMR0_CSR |= LPTMR_CSR_TEN_MASK;
  while (!(LPTMR0_CSR & LPTMR_CSR_TCF_MASK));
  LPTMR0_CSR &= ~LPTMR_CSR_TEN_MASK;
  return;
538 次查看
vahidnoori
yes .exactly ping.
