Hi all,
Can anybody provide/point to the datasheet/ connection details of GD-6363P LCD used on TWR-SLCD?
Pramod TM
解決済! 解決策の投稿を見る。
See http://www.utasker.com/docs/uTasker/uTasker_SLCD.pdf
and the attached drawings
Mark
Kinetis: µTasker Kinetis support
SLCD: http://www.utasker.com/docs/uTasker/uTasker_SLCD.pdf
For the complete "out-of-the-box" Kinetis experience and faster time to market
Mark
Hi Mark,
Thanks for the answer. I'm trying to code for TWRPI_SLCD on TWR-KL25, which doesnot have a built-in LCD controller. I'm referring to http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3412.pdf, http://www.utasker.com/docs/uTasker/uTasker_SLCD.pdf and http://www.atmel.com/images/doc8103.pdf for understanding. From the waveform, i gather that Vdd/2 is necessary, and we need a resistor divider on backplanes to achieve that. But on TWR board/TWRPI-SLCD board, I dont see any such resistors.
My question here is that "is there any other way to do so?" Otherwise, i don't see a rational explanation for providing TWRPI-SLCD on TWR kits with no LCD controllers/ resistor divider?
Pramod TM
PS:I can solder resistor network for each of the COM pins. Just being curious.
Since the SLCD requires many lines for its control, and each has to switch at a certain frequency (and multiplex) with different analogue levels it doesn't make a lot of sense to do this in software with a chip that doesn't include an SLCD controller.
The following Kinetis include SLCD which can be simply configured and used without an processor overhead so it would be wiser to choose a suitable device rather than starting a complicated hardware/software development which will them require much of the processor's power to handle it.
- K30
- K40
- K51
- K53
- KL43
- KL46
(maybe more)
Mark
KL25: µTasker Kinetis FRDM-KL25Z support / µTasker Kinetis TWR-KL25Z48M support
