an2295sw usage
Search instead for
an2295sw usage
hotashu
I run an2295sw kinetis L code with CW10.6, i can download this code to my KL25 frdm board well, when lauch debugger, it stops at main(). when i step over the code . it jumps to Boot_ResetMCU routine. what's the problem? (my an2295 is the latest download from freescale website)
void Boot_ResetMCU(void)
{   SCB_AIRCR = SCB_AIRCR_VECTKEY(0x5FA) | SCB_AIRCR_SYSRESETREQ_MASK;   while(1)   {};  }
mjbcswitzerland
Specialist V
Hi Hotas
Although not the same UART method as described in AN2295 there are KBOOT and SREC UART loaders for your board here:
http://www.utasker.com/kinetis/FRDM-KL25Z.html
They work directly with CW10.6 in case that is the main requirement (although also with KDS, IAR, Keil, Rowley, Green Hills, CooCox, Atollic and VisualStudio).
Mark
Kinetis: µTasker Kinetis support
KL25: µTasker Kinetis FRDM-KL25Z support / µTasker Kinetis TWR-KL25Z48M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
Jorge_Gonzalez
Hello hotas holy:
I think the CodeWarrior project is not functional, only the IAR and Keil projects. Sorry for that inconvenience.
There is also a serial bootloader developed by colleague Erich Styger with Processor Expert, described and shared in the next tutorial:
http://mcuoneclipse.com/2013/04/28/serial-bootloader-for-the-freedom-board-with-processor-expert/
Regards!,
Jorge Gonzalez
