Hardware and Configuration:
TWR-KV58F220M
TWR-SER (J2 3-4, J3 2-3, J12 9-10)
IDE : IAR 7.8
SDK : 2.3.1
Example: lwip udp echo
I am trying out the lwip udp echo example on my TWR-KV58F220M and TWR-SER. I am sure I have configured the jumpers correctly:
J2 for 50MHz PHY Clock
J3 for 50MHz CLOCKIN0
J12 for RMII
When I run the udp echo exampe on the dev board, I notice a lot of packet drops. If I ping the IP address defined in the example, I do not always get a reply. Also, I wrote a simple packet sending program to send udp packets to the KV5 and it does not get 7% of packets sent to it. Anyone have ideas? I suspect that this isn't normal.
解決済! 解決策の投稿を見る。
The TWR-KV58F220M board 50MHz clock need resourcing from TWR-SER board, please disable the TWR-KV58F220M board 50MHz oscillator with J29 shunt on.
For the detailed clock setting for TWR-KV58F220M board, please check below info at [lwip_udpecho] project <readme.txt> file:
Board settings
TWR-SER:
- RMII mode - J2 3-4 shunt on, J3 2-3 shunt on, J12 shunt on 9,10.
Clock setting for TWR-KV58F220M board
- J29 1-2 shunt on.
- Place R110 with 0 Ohm resister.
- J11 no shunt, to avoid wrong reset button behaviour.
BTW: The MCUXPresso SDK V2.3.1 for TWR-KV58F220M board [lwip_udpecho] project supported below IDE software:
Toolchain supported
- IAR embedded Workbench 8.11.3
- Keil MDK 5.23
- GCC ARM Embedded 6-2017-q2
- Kinetis Development Studio IDE 3.2.0
- MCUXpresso10.1.0
The major issue is the TWR-KV58F220M board should use TWR-SER board 50MHz CLKIN.
Wish it helps.
Mike
Board settings
TWR-SER:
- J29 1-2 shunt on.
Toolchain supported
- Keil MDK 5.23
- MCUXpresso10.1.0
Wish it helps.
Mike
