Which are the options for programming a MKW41Z custom board?
605件の閲覧回数
javiermonrealtr
Good evening,
I tested the FRDM-KW41Z evaluation board and I've decided to design a custom board with the MKW41Z MCU as its core. But what options do I have for programming it, and which do you recommend?
I know two: Using the U-MULTILINK tool (https://www.digikey.es/product-detail/es/nxp-usa-inc/U-MULTILINK/U-MULTILINK-ND/2660579) or using an FRDM-KW41Z as a programmer (https://mcuoneclipse.com/2015/08/19/using-the-freescale-freedom-frdm-kl43z-to-debug-other-boards/)
I will build three units of the custom board device, so I'm looking for the easiest although not most efficient programming option.
Thanks in advance!
ラベル(2)
472件の閲覧回数
BlackNight
You have more options, for example:
- Segger J-Link (J-Link Debug Probes | SEGGER - The Embedded Experts ), e.g. for non-commercial the J-Link EDU (starts at around 20 Euro) which are available from distributors too
- If you are using the MCUXpresso IDE, there is the LPC-Link2 (around 20 Euro too), see Custom 3D Printed Enclosure for NXP LPC-Link2 Debug Probes | MCU on Eclipse
I hope this helps,
Erich
473件の閲覧回数
BlackNight
I hope this helps,
Erich
