Here's what I have:
FRDM-KL25Z
Keil MDK 4.60
CMSIS-DAP_OpenSDA.S19
DEBUG-APP_Pemicro_v102.SDA
MSD-FRDM-KL25Z_Pemicro_v107.SDA
What I want is to be able debug a program and have serial
communications through the same USB cable.
Here's what I have achieved:
A) CMSIS-DAP_OpenSDA.S19
Can download and run/debug app, but no serial comms.
B) DEBUG-APP_Pemicro_v102.SDA
C) MSD-FRDM-KL25Z_Pemicro_v107.SDA
Can drag/drop to download and run, serial comms works,
but no debug. Only the pre-compiled .srec files .
Keil compiler generates HEX or AFX files that can't be
drag/drop and since no debug, compiler download does
not work. So can't create new apps.
Is there an SDA that supports debug and comms?
Am I doing something wrong?
On a separate note, there seems to be two totally different
ways of referring to registers:
The examples for this board that are part of the Keil install
(Blinky) looks like this
SIM->SCGC5 |= (1UL << 10) | (1UL << 12);
PORTB->PCR[18] = (1UL << 8);
The Freescale KL25_Sample_Code.exe unpacks to a pile
of directories. In the klxx-sc-baremetal source files it looks
like this:
SIM_SCGC5 |= (SIM_SCGC5_PORTA_MASK)
Why are there two styles? Which should I use.
On another separate note, I can't find an example directory
for a Keil version of demo program that the board is shipped with.
I did an IAR version:
kl25_sc\klxx-sc-baremetal\build\iar\FRDM_KL25ZDemo
Solved! Go to Solution.
Philip
Both the DEBUG-APP_Pemicro_v102.SDA and MSD-FRDM-KL25Z_Pemicro_v105.SDA applications support USB CDC serial comms (via the KL25's UART0 to the K20 SDA MCU on the Freedom board).
The CMSIS-DAP_OpenSDA.S19 debug App however does not include a USB CDC serial driver at this time but my understanding is that it will do so in future version of this SDA App...
More on OpenSDA at:
http://www.freescale.com/files/32bit/doc/user_guide/OPENSDAUG.pdf
The differences between the SDA applications are covered in detail in Avnet's Kinetis-L hands-on Speedway Workshops! :-)
http://www.em.avnet.com/KinetisLSpeedway
Peter
Philip
More on OpenSDA at:
Peter
Hi Peter,
Your answer that DEBUG-APP_Pemicro_v102.SDA does support USB CDC serial comms contradicts
item B in my original post. So that's where I started looking. Eventually I uninstalled the device drivers
and re-installed them, and now I see both the Debug port and the Comms port in the Windows device
manager display. Once I got to this point I was able to get back to debugging my program, and also
having serial output to a console terminal.
Philip
this tutorial/demo shows how to debug and to do serial communication through the OpenSDA USB cable:
A Shell for the Freedom KL25Z Board | MCU on Eclipse
Erich
Thanks for your reply and link to your blog site. I have spent several hours reading your excellent
articles/tutorials.
and this is incorrect. I have now got this going. See my response below to Peter.
On a more tragic note, I just spent about 10 hours trying to debug the I2C link to the MMA8451 on my
board, with the link hanging up at random times. I eventually found it was related to the way the
I2C clock was created (choice of the various control values). Even creating the same frequency but
with different combinations of control values could cause a success or failure. Then I found your
article describing this problem.
In case anyone else is having this problem, I found the following works:
Crystal is 8MHz , CPU clock is 48 MHz, Bus Clock is 24 MHz
I2C0 F register (@ 0x6000_6001) value is 0x14 Mult field is 0b00 -> mul = 1
and ICR is 0b010100 which gives an SCL divider value of 80
Thus 24MHz/80 = 300KHz for SCL
Also, various examples I found have a delay/pause at the end of each read or write
sequence. I adjusted the delay to be 20us so the gap between each sequence is
real obvious on an oscilloscope.
