Using the FRDM-HB2000-EVM evaluation board with a function generator
1,087 次查看
carterhough
I recently purchased the FRDM-HB2000-EVM evaluation board to use for a customer demo. On page 19 of the User's guide (Doc. #: KTFRDMHB2000EVM), it illustrates the hardware configuration for using this board with a function generator rather than the FRDM-KL25Z board and SPIGen interface. I followed the setup instructions, but am receiving a 'Status Fault' and cannot seem to figure out how to activate the output.
Note: I configured the board with the FRDM-KL25Z board and SPIGen interface and everything works fine.
Is there any additional documentation on configuring this board with the function generator?
879 次查看
miduo
For your case, did you install the SPI H-Bridge driver based on HB2000 and HB2001: http://www.nxp.com/files/analog/doc/user_guide/HB2000-HB2001SWUG.pdf.
