Using Uart with Kinetis KE02 without processor expert
次の代わりに検索
245件の閲覧回数
Ofgallo96
Hey guys, i'm trying to use uart peripheral with mke02z32vlc4, with processor isn't hard but for my application i need optimize the size code because i have many other modules.
The solution was try make all project with manual register write, but, when i put some value in any config register peripheral the program enter in a loop to irq default handler, in the debug is something like:
-> write register ----> defalut irq handler ---|
This occurs with other peripherals too, SPI, ADC, ... the line that crash the program is:
UART1_SC2 = 0x0C; //write config to enable uart
And the entire code is:
I think that is a problem with the interrupt configs in kinetis, but i don't have many experience with this, so please, if anybody can help me I will appreciate it.
215件の閲覧回数
Ofgallo96
Hey everyone, i'm fixed the problem, so i'm going to share the solution only if someone else need it.
Basically i forgot enable the clock source for the peripheral, so, setting the right bit in the register SIM_SCGC the peripheral works, for UART0 you can use a mask included in the header for ke02z:
SIM_SCGC |= SIM_SCGC_UART0_MASK;
216件の閲覧回数
Ofgallo96
