USB CDC Example Receive only fail
499 次查看
etronic_arg
I just trying to do a Virtual COM communication based on the USB CDC example from SDK.
I tested the example with success.
I cancel the "echo" part of the APPTask:
static void APPTask(void)
    usb_status_t error = kStatus_USB_Error;
    if ((1 == s_cdcVcom.attach) && (1 == s_cdcVcom.startTransactions))
        /* User Code */
        /* endpoint callback length is USB_CANCELLED_TRANSFER_LENGTH (0xFFFFFFFFU) when transfer is canceled */
        if ((0 != s_recvSize) && (USB_CANCELLED_TRANSFER_LENGTH != s_recvSize))
            int32_t i;
			/* Copy Buffer to Send Buff */
            for (i = 0; i < s_recvSize; i++)
                s_currSendBuf[s_sendSize++] = s_currRecvBuf[i];
			s_recvSize = 0;
        if (s_sendSize)
            uint32_t size = s_sendSize;
			s_sendSize    = 0;
            error = USB_DeviceCdcAcmSend(s_cdcVcom.cdcAcmHandle, USB_CDC_VCOM_BULK_IN_ENDPOINT, s_currSendBuf, size);
            if (error != kStatus_USB_Success)
                // Failure to send Data Handling code here
If I send "HELLO" wth a terminal from a PC, the first time s_currSendBuf fills with the characters.
With the second "HELLO" I send, the terminal stucks.
I just need to receive characters but not send them back.
What would be the right way to do it?
标记 (3)
411 次查看
xiangjun_rong
Yes, this is a good solution. After you have data, just call the the function to send.
Xiangjun Rong
USB_DeviceCdcAcmSend();
450 次查看
xiangjun_rong
Can you tell us the part number you are using?
XiangJun Rong
437 次查看
etronic_arg
Hello XiangJun,
The part I'm using is the MK27FN2M0VM115 in a custom board, but I also tested it in a FRDM-K64F.
I solve the issue partially calling the USB sending fuction without data after receiving:
 if (s_sendSize)
			s_sendSize    = 0;
            error = USB_DeviceCdcAcmSend(s_cdcVcom.cdcAcmHandle, USB_CDC_VCOM_BULK_IN_ENDPOINT, NULL, 0);
Is there a better solution?
标记 (1)
412 次查看
xiangjun_rong
Xiangjun Rong
