UART for communication
1,669件の閲覧回数
arbnorzeqiri
Hi all,
I'm new to Kinetis MCUs and I want to know how to work with UART, does it have any library for that ?
p.s. My MCU is MKL05Z
タグ(2)
780件の閲覧回数
martynhunt
Hi Arbnor,
You can find some sample code for the KL05 on the following web page: KL05-SC
The download you are looking for is KL05-SC. Inside there should be an IAR project that uses UART and I2C.
Also, the reference manual has a description of all the UART registers. You can find it and other documentation here: KL0 Documentation
Let me know if you have any questions.
Martyn
4 返答(返信)
780件の閲覧回数
pradyumnakammar
Thank you Martyn ... UART0 clock was not the problem i had not disabled one of the interrupts which was interfering.
781件の閲覧回数
martynhunt
Hi Arbnor,
Martyn
780件の閲覧回数
pradyumnakammar
hi
martynhunt
im new to Kinetis L 05 MCUs can you give me examles ti use UART intrrupt for communication serially ?? i have referred KL05-SC n used polling method
i want to use the interrupt method during wake up (MCU waking from LLWU pin) then reconfig to polling type
when i tried to do the above at the later part when its waiting in a while loop   @ while(!(UART_S1_REG(channel) & UART0_S1_RDRF_MASK));it goes to hard fault
i dont know how to solve ... need assistance
regards
Pradyumna
780件の閲覧回数
martynhunt
Hi Pradyumna,
Have you made sure that the UART0 clock is enabled by setting SIM_SCGC4[UART0] = 1. Also, what clock source are you using for UART0? (SIM_SOPT2[UART0SRC]).
Martyn
