UART DMA and CTS
UART DMA and CTS
692 次查看
lsrbigfoot
Does the UART-CTS input signal (when activated) have the ability to block/unblock UART-Tx DMA traffic automatically (without processor intervention)?
If not, then what extra controls are required to make this happen?
518 次查看
mjbcswitzerland
Specialist V
Check the UART MODEM register for the part type that you are using.
The control bit TXCTSE enables CTS control of the transmitter, which also pauses DMA transmission.
Mark
519 次查看
mjbcswitzerland
Specialist V
Mark
