Trouble with understanding FRDM-KEA 128 board
Search instead for
tejasr
I'm just starting with the board and I have a few questions regarding the pin layout. In the image attached, I've found many pins to be duplicated/repeated. I am having problems reading input from any of the GPIO pins. I'm using the S32 Design Studio. The outputs are working fine.
To set up a pin as an input, I've used the following commands
GPIOA_PDDR &= ~(1<<PTD2);
GPIOA_PIDR &= ~(1<<PTD2);
PORT_PUE0 |= 1<<PTD2;
The flow is not entering the if condition -   if( (GPIOA_PDIR) & (0<<PTD2)).
I've already posted a question regarding this and did get a response. But since I'm new to all this, I think it's better if someone can post relevant links so that I can learn.
Thanks in advance.
Robin_Shen
Hi Tejas,
We can discuss it in similar question: Problem in reading input from gpio pin in frdm-kea128.
Robin
