Touch Tuning based on KE15Z Help Needed
搜索替代
462 次查看
arunsharma
Hello Everyone,
I am new to the Kinetis Series of Micro-controller and I am using MKE15Z micro-controller for the touch-based project, all of my keys are configured as self-capacitance electrodes.
I used the touch_sensing example from the SDK and modified it to suit my needs. And here is the visualization on one of the electrodes.NXP_Touch_Tuning_1.png.
Now I am in the phase of tuning the touch parameters, but to start it looks complicated to me, although I am taking reference from the touch manual to help me get started.
In this case (shown above), the dead-band signal and the predicted signal are very close, this means that I have to reduce it? or there is a way I can increase the gain of the predicted signal.
I checked the examples and found that usually the dead-band signal is kept 600+baseline level, in my case I have just put this value to 400.
When I touch the Electrode, the response is very slow, and when is release the Electrode, the response is even slower.
I have used a LED, which gets turned on when Electrode is press and off when Electrode is released.
How to prevent this?
const struct nt_electrode El_1 = {
 .shielding_electrode = NULL,
 .multiplier = 0,
 .divider = 0,
 .shield_threshold = 5,
 .shield_gain = 30,
 .shield_attn = 1,
 .shield_sens = 800,
 .keydetector_params.usafa = &nt_keydetector_usafa_El_1,
 .keydetector_interface = &nt_keydetector_usafa_interface,
 .pin_input = 2,
 .gpio_input = GPIO_PTE10,
 .baseline_level = 36363,
const struct nt_keydetector_usafa nt_keydetector_usafa_El_1 = {
 .signal_filter.coef1 = 2,
 .base_avrg.n2_order = 12,
 .non_activity_avrg.n2_order = 15,
 .entry_event_cnt = 4,
 .deadband_cnt = 4,
 .signal_to_noise_ratio = 2,
 .min_noise_limit = 200,
 .dc_track_enabled = 1,
 .dc_track_cnt = 100,
Another problem is with FreeMASTER, every time I have to change the colors of the signal as they are reverted back to black color always (FreeMASTER Version 3.0.2.6)
So, to summarize I want to know if there is a document, which can help me in tuning the touch parameters for my board.
Any webinar, tutorial, document link will be extremely helpful.
Thanks in advance.
标记 (1)
335 次查看
FelipeGarcia
Hello Arun,
I don’t know if you have already checked our NXP Touch Development guide. Here you will find a lot of configuration and description about our touch library.
Felipe
336 次查看
FelipeGarcia
Hello Arun,
Felipe
