TWR-POS-K81 QSPI FLASH
搜索替代
802 次查看
devilavanyaanda
Requirement:    QCB for the QSPI Flash Part no: MT25TL512HBA8E12.
Environment:    The TWR-POS-K81 KIT is supplied with a QSPI Flash Part no: MT25TL512HBA8E12. Through the  IAR IDE, using USB-MULTILINK  we are loading PAYMENT DEMO application in TWR-POS-K81 . Payment demo application gets loaded in both internal flash and external QSPI flash memory and PAYMENT DEMO application works fine.
What we want to do:
  • We want to load the outputfile, paymentdemo.sb in to the TOWER-POS-K81 board using blhost.exe or mfgtools.exe
  • We understand that in order to do this, first we need to create a qspi_config_block_generation.c containing QCB information suitable for MT25TL512HBA8E12 and compile using CodeBlocksIDE to generate a  qspi_config_block_pos.bin.
  • Using the document Kinetis Bootloader QuadSPI User's Guide paymentdemo.bd is required to be created.
  • Further using the Elftosb.exe and paymentdemo.bd prepared for paymentdemo.srec and qspi_config_block_pos.bin the  paymentdemo.sb shall be created.
  • Further this paymentdemo.sb is loaded into the TOWER-POS-K81 board using blhost.exe or mfgtools.exe
What we want:
  • QCB file suitable for MT25TL512HBA8E12
Note: We tried to create a QCB file at our end, but unsuccessful.
Thank you
6 回复数
688 次查看
nxf58904
MT25TL512HBA8E12 's difference is flash space , but cmd and main timing sequence is same .
Please have a try .
Jianyu:
TIC
688 次查看
devilavanyaanda
 Hello Jianyu,
We changed flash space and tried but still its not working.
Thanks in advance
688 次查看
nxf58904
https://www.nxp.com/docs/en/user-guide/MBOOTQSPIUG.pdf
Jianyu:
TIC
688 次查看
devilavanyaanda
Hello Jianyu,
We required QCB file suitable for MT25TL512HBA8E12 IC
In "MBOOTQSPIUG.pdf" document the QCB for MT25TL512HBA8E12 IC  is not mentioned.
Thanks in advance
688 次查看
nxf58904
Refer this link https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true ,chapter 3.3.3,please have a try .
Jianyu:
TIC
688 次查看
devilavanyaanda
Hi Jianyu,
This above link is directing to the below link
Software | NXP
 we are unable to refer chapter 3.3.3, Please Mention the Document name.
Thanks in advance
