TWR-K60N512 and eGUI HelloWorld
Search instead for
Glogov_Kolac
Does anybody have succes with eGUI 2.01 HelloWorld example running under MQX 3.7 RTOS.
I try this example but there is no text, image or any kind of content on TWR LCD. To mention that I am using elevatro SPI rather than 16b mode. Is there anyone who have succes with this example and how ?!
Gargy
 on latest release of eGUI on web is example with K60 and eGUI over SPI.
Good luck
Glogov_Kolac
I have tryed all examples for TWR K60N512 in eGui 2.01 (baremetal, mqx 3.7 and 3.6) and after running the code there is no content on my TWR LCD. I configured it to use external SPI (SW1 = 01111110). If somebody have succes with this example and how ?
Gargy
The examples, should work correctly.
The issue could be done by HW, did you tried the LCD on any other MCU? TWR-MCF51CN128 ??
Glogov_Kolac
TWR LCF works fine with builtin demo (driven by onboard Coldfire JM128 MCU). The problem is when I try to run demo from my Kinetis TWR Mcu acros the elevator board bypasing JM128. Is there some extra config on HW or SW for External SPI running ?
Dekiru
Hi, - Did you clear the JM128 chip? If not, there should be conflict and you may not be able to use LCD - I think that there is conflict between LCD interface and Flexbus, so try to not use flexbus (and MRAM of course) when using TWR LCD Regards
Gargy
Good point, I forgot on this .
I§m ussually using this simple project (CW 6.3).
Glogov_Kolac
I will try to solder pins of reset taster in order to keep JM128 in reset all the time. This is (IMHO) better idea than flashing JM (besides that I dont have BDM flasher).
Gargy
 on TWR-LCD JM128 is some kind of bootloader that you could use instead of BDM. :smileyhappy:
LuisCasado
Hello Here you can find a valid app for working with eGUI and JM will not cause interferences. Notice that not only the reset line is the issue but touch screen control. http://www.towergeeks.org/forum/topics/twrk60n512-and-tft best regards Luis
LuisCasado
I forgot tell you that you can use bootloader for flashing Luis
