Hi NXP
I just try to build EEPROM emulation driver for KEA128 and KEA8 project at the Code Warrior
but when i import project, problem has occurred
I think this problem is caused by not installing the right software. I couldn't find a right codewarrior installing software
please can i have download link ? and do you have any idea about that problem?
product : TRK-KEA8
project : EEPROM emulation driver for KEA128 and KEA8
error detail
Solved! Go to Solution.
Hi lim,
Sorry for my last reply!
According to the error message, seems that you did not choose Kinetis when install the CodeWarrior.
Robin
Hi lim,
Please try to copy and paste the folder KEA_SGF180 to a place.
And then import the example: KEA_SGF180\Demos\build\TRK_KEAZN8\cw
I am able to build it by using CodeWarrior11.1.
Robin
Hi lim,
Robin
Thank you i solved that problem
Thank you very much
