SPI transfer with a KL03
1,117 次查看
javierhernande1
I need to perform a SPI communication with a slave device with a KL03 mcu.
I need to adjust 3 register.
First step is programming 0xF register as 0x000000 for reset, the delay 300ms.
Second step is programming 0x1 register as 0x45E15 then delay 30ms
Last step is programming 0x3 register as 0x0FFDC
I need to perform 3 txTranfers? or is possible in one transfer?
And, Is there any function to wait on ms?
printf("\n\r SPI Master Start...\n\r");
 * userConfig.enableStopInWaitMode = false;
 * userConfig.polarity = kSPI_ClockPolarityActiveHigh;
 * userConfig.phase = kSPI_ClockPhaseFirstEdge;
 * userConfig.direction = kSPI_MsbFirst;
 * userConfig.dataMode = kSPI_8BitMode;
 * userConfig.txWatermark = kSPI_TxFifoOneHalfEmpty;
 * userConfig.rxWatermark = kSPI_RxFifoOneHalfFull;
 * userConfig.pinMode = kSPI_PinModeNormal;
 * userConfig.outputMode = kSPI_SlaveSelectAutomaticOutput;
 * userConfig.baudRate_Bps = 500000U;
 SPI_MasterGetDefaultConfig(&userConfig);
 srcFreq = SPI_MASTER_CLK_FREQ;
 SPI_MasterInit(SPI_MASTER, &userConfig, srcFreq);
/* Init Buffer*/
 for (i = 0; i < BUFFER_SPI; i++)
 srcBuff[i] = i;
/*Start Transfer*/
 xfer.txData = srcBuff;
 xfer.dataSize = BUFFER_SIZE;
 SPI_MasterTransferBlocking(SPI_MASTER, &xfer);
963 次查看
nxf56274
You can use "nop" to write a delay function by yourself. You should perform three transfers
TIC
964 次查看
nxf56274
TIC
