SPI Chip Select
SPI Chip Select
860 次查看
josephchen
I'm using Kinetis MCUs. I wonder if it is possible to connect two SPI slave devices shared the same SS line. One of the SS lines contains a NOT logic gate so I can select the slave device by changing its GPIO value in callback function. Is it possible?
625 次查看
jeremyzhou
Hi Joseph,
After learned your statement, I think this scenario can work out.
But I don't consider this method is good enough, I will prefer to share SPI_MISO、SPI_MOSI、SPI_SCLK pin, then use the different GPIO as the SS pin to select the external device.
Ping
