SDK build: No middleware selection for Channel sounding
979 次查看
BLEDev
I'm trying to build SDK and run channel sounding examples on KW45 LOC board following this user manual KW45B41Z-LOC Board User Manual (nxp.com).
But it seems SDK builder has no option Middleware "Wireless Localization". Could you help check?
5 回复数
795 次查看
sysumst111
Hey, have you received the 'Wireless Localization' SDK? I'm also trying to run the channel sounding examples. If you have it, could you please send me a copy as an attachment? Much appreciated
953 次查看
Ricardo_Zamora
Hope you are doing well. Do you have the KW45B41Z-LOC?
I sent you a private message.
Ricardo
355 次查看
aliyasser7
Can you send me the wireless localization SDK also?
I have been reviewing the AN13974 - Bluetooth Low Energy Localization Application Note (Rev. 1.2, June 2024) and would like to implement the solutions described in the document. However, I am unable to locate the associated code or SDK examples referenced within the application note.
731 次查看
jorisvergeer2
@Ricardo_Zamora Can you send me the wireless localization SDK also?
I have KW32W148, but that should also KW45 code. I'd be completely happy if Channel Sounding and Ieee802.15.4 can run both on the same board. I need the results of Channel Sounding to be transmitted over Ieee802.15.4 to our data collection network.
823 次查看
sysumst111
I have the same problem, can you send me a private message?
