I'm using the TWR-K64 board, TWR-SER along with the TWR-MEM board in the Tower system. What are the recommended SPI-prescaler settings to get the K64 to communicate with SPI Flash on the TWR-MEM board?
The TWR_MEM Jumpers for this chip are as follows: J-14(1-2) and J4(1-2).
Here are my software settings (Using KSDK 1.2.0):
DSPI_HAL_SetDelay(m_pSpiBase[m_instance], (dspi_ctar_selection_t)configData.clkTransAtt, 0, 4, kDspiPcsToSck);
DSPI_HAL_SetDelay(m_pSpiBase[m_instance], (dspi_ctar_selection_t)configData.clkTransAtt, 0, 4, kDspiLastSckToPcs);
DSPI_HAL_SetDelay(m_pSpiBase[m_instance], (dspi_ctar_selection_t)configData.clkTransAtt, 0, 1, kDspiAfterTransfer);
DSPI_HAL_SetContinuousSckCmd(m_pSpiBase[m_instance], SYS_FALSE);
configData.clkTransAtt = SPI_CLK_TRANSFER_ATTRUBUTES configuration (below enumeration)
/*! @brief DSPI Clock and Transfer Attributes Register (CTAR) selection*/
typedef enum SPI_CLK_TRANSFER_ATTRUBUTES
SPI_CLK_TRANSFER_ATTRUBUTES_MASTER_OR_SLAVE = 0, /*!< CTAR0 selection option for master or slave mode */
SPI_CLK_TRANSFER_ATTRUBUTES_MASTER, /*!< CTAR1 selection option for master mode only */
SPI_CLK_TRANSFER_ATTRUBUTES_EOL
} SpiClkTransferAttr_t;
Clock info from the Oscilloscope
kDspiPcsToSck = 614ns
kDspiLastSckToPcs = 614ns
Spec on this device is (min of 5ns)
Timing between clock cycles (rising edge to rising edge) is 2.074us
Spi Port Configurations are as follows:
PIN MUX
#if(DEVELOPMENT_BOARD_TYPE==BLD_USING_TWRK64F120M_DEV_BOARD)
BSP_PORT_PTD_PIN3, BSP_PORT_FUN_ALT_2 //SPI0_SIN (MISO)
BSP_PORT_PTD_PIN2, BSP_PORT_FUN_ALT_2 //SPI0_SOUT (MISO)
BSP_PORT_PTD_PIN0, BSP_PORT_FUN_ALT_2 //SPI0_PCS0 (ChipSel)
BSP_PORT_PTD_PIN1, BSP_PORT_FUN_ALT_2 //SPI0_SCLK (SpiClock)
#endif
PORT/BUS: BSP_SPI_BUS_SPI_0
IRQ Priority: Normal
500000UL, ///< U32 baudRate; in bps
8, ///< U8 bitsPerFrame; defines the frame size for the device transaction; range is 4 to 32
false, ///< BOOL contChipSelect; if set true, chip select always remains active (not useful)
SPI_CLK_TRANSFER_ATTRUBUTES_MASTER_OR_SLAVE, ///< SPI_CLK_TRANSFER_ATTRUBUTES_t clkTransAtt; Master or Master/slave role (CTAR0, or CTAR1)
SPI_PCS0, ///< SPI_PERIPHERIAL_CHIPSELECT_t peripheralCS; selection for the device chip select pin
SPI_PCS_ACTIVE_LOW, ///< SPI_PERIPHERAL_CHIPSELECT_POLARITY_t polarityCS; shift polarity for the chip select pin
SPI_CLOCK_POLARITY_ACTIVE_HIGH, ///< SPI_CLOCK_POLARITY_t clkPolarity; clock polarity for the shift (idle state of SCLK)
SPI_CLOCK_PHASE_LATCH_ON_LEADING_EDGE, ///< SPI_CLOCK_PHASE_t clkPhase; clock phase for the shift;
-SPI_CLOCK_PHASE_LATCH_ON_LEADING_EDGE = command data is latched on leading edge of the clock pulse
SPI_MSB_TRANSFER_FIRST, ///< SPI_SHIFT_DIRECTION_t shiftDirection; MSB or LSB first
#endif
Thanks, in advance.
Scott
