I am working on a project and I am using KW38 evaluation board for it. I want to read analog data from 2 pins and sample that data at 50KHz frequency. Since I am new to this, any documentation or sample code will be appreciated so that I can get an Idea on how to proceed with it.
Vipul Notani
You can download the sdk in https://mcuxpresso.nxp.com/en/select. The sdk has many example and document.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
Hi @notanivipul
What is the "evaluation board" board are you using (ie is it a Tower or Freedom board)? Also, what development tool and driver software are you looking to use? If it's MCUXpresso and the NXP SDK, then there will be several example projects which use the ADC that you can look it.
Hi @myke_predko
I am using Freedom KW38 evaluation board. With that I am using MCUXpresso IDE with NXP-SDK.
Please let me know which examples to look for
Vipul
In MCUXpresso, goto "Import SDK example(s)..." in the Quickstart Panel and then look through "Driver examples" and "Demo apps".
There should be at least a half dozen example projects there for you.
