Question on freeMASTER
次の代わりに検索
837件の閲覧回数
vpandey1
Hi there
I'm new to using freeMASTER & would appreciate if someone can help with following
1. How to use a command line to issue START command to freeMASTER to start with logging. For our test application running NI labview, command needs to be issued to freeMASTER to start the data logging. The unit under test is connected to PC through USB port and at power up embedded code will start with internal checks on unit & start outputting messages on USB com port. The power up is done using labview code.
2. Once data is logged need to save logged data to excel file. Please help on how to save data to excel file.
Vinod
タグ(1)
742件の閲覧回数
FelipeGarcia
Hello Vinod,
I recommend you to check the below community thread where your questions are explained in detailed.
Export data from Freemaster
Hope it helps!
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored.
742件の閲覧回数
vpandey1
Hi All
We are testing PCBA's and using freemaster as tool to communicate with the board under test.
The PC comm port changes from board to board. Is there a way to fix the PC comm port used for freemaster?
Is there a active-x command to set the comm port?
thanks
Vinod
