Problems with Sleep Mode on KL05Z
saliheberisha
I am having problems waking up from sleep/stop mode,I set the external pin in LLWU  setting enabled and in the routine of detecting that interrupt set
Cpu_SetOperationMode(DOM_RUN, NULL, NULL); but I think the processor isn't detecting any interrupt. Also when entering the stop mode (VLLS) the board losses connection . All I need is a blinking led and via an external interrupt(falling edge) to set the processor in sleep and wake it up when rising edge on the interrupt is detected. I am using processor expert.
main looks like this :
int main(void)
  /* Write your local variable definition here */
  /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
  PE_low_level_init();
EInt1_Enable();
  Cpu_VLPModeEnable();
  while(1){
  Bit1_SetVal();WAIT1_Waitms(100);
  Bit1_ClrVal();WAIT1_Waitms(100);
in events.c
void EInt1_OnInterrupt(void)
  WAIT1_Waitms(100);
  if (EInt1_GetVal())
   Cpu_SetOperationMode(DOM_RUN, NULL, NULL);/* Write your code here ... */}
else {
  Cpu_SetOperationMode(DOM_STOP, NULL, NULL);
Also tried this :
void Cpu_OnLLSWakeUpINT(void)
v = Cpu_SetOperationMode(DOM_RUN, NULL, NULL);// v is a char
  Bit1_ClrVal();WAIT1_Waitms(100);// just to see if it is entering this function
This is my configuration of CPU
chris_brown
Hi Saliheberisha,
First, what debugger are you using?  Some debuggers will lose connection when entering low power modes because the debug circuitry is turned off when you enter debug mode.  Other debuggers will simply force the part to enter a pseudo low power mode.  So in either case, it is not recommended to enter a low power mode when debugging.
Second, it sounds like maybe you are not handling ACKISO properly.  Remember that Processor Expert does not handle this for you.  So you will need to add some start-up code BEFORE the Processor Expert initialization runs.  See the screenshot below.
Hope this helps,
Chris
chris_brown
Hi Saliheberisha,
Hope this helps,
Chris
donejtaelshani
what if I want to use LPTMR0 as an wake up timer for the sleep mode, how can i set the time( as i read it says on compare register ) and where should i set it, like if i want the timer interrupt to happen every 3s and i am using an external 32kHz oscillator. should i add a component for doing that or just write the code and select enable at LLWU settings ?
joginderrana
Hi I am using MK20DX128VLH5 microcontroller. I am not able to enable sleep mode in this controller. Please help to get rid of this problem. I will be grateful if you provide me with snap shot of cpu settings and syntax parameters for Cpu_SetOperationMode();
joginderrana
HI Erich,
I have been through the example code and have my controller enabled on sleep mode now.
Thanks.
joginderrana
Hi Erich,
Now I have my board enabled on stop mode and can be triggered to exit stop mode using external interrupt through LLWU pins. I want to trigger it through UART. I am facing problem here. Please help me  to enable llwu interrupt to wake up the controller by sending active edge through UART.
