Problem with SafeRoutineCaller while overwriting flash.
939 次查看
sufyanalamad1
My setup is a Cortex-M0+ (MKL15Z128VFT4) running freeRTOS.
I am trying to write to flash using the ProcessorExpert components. Inside of of method IntFlashLdd2_Main, SafeRoutineCaller() is used. This function has been confirmed to be the point of failure. The processor resets to __vect__table 0x00.
Our bootloader does not use freeRTOS, and also writes to flash, but works perfectly. This leads me to think that the issue arises from the freeRTOS ports taskENTER_CRITICAL() and taskEXIT_CRITICAL().
However our generated watchdog clearing function also uses the above freeRTOS functions, and that is working fine.
I would appreciate some help resolving this issue.
Thanks.
4 回复数
848 次查看
danielchen
Hi sufyanalamad
I would suggest you increase the stack size of the flash task to 1000 or bigger to see whether it helps.
848 次查看
sufyanalamad1
Hello Daniel, thanks for responding.
I created a separate task just for the flashing, it has 2100 bytes of stack allocated to it. I am unable to allocate more due to what I think is heap fragmentation, as I am deleting some tasks before creating this one.
Anyways, 2100 sounds like it should be enough -- yet it still fails in the same way. For the flashing, I am doing 16 bytes at a time, exactly like our bootloader.
Do you still think it's a stack problem?
Thanks.
EDIT: I have just managed to try it with 8192 bytes allocated to the flashing task. Still the same problem.
848 次查看
danielchen
Hi sufyanalamad
From your description, it is not a stack problem.  could you share your project for further analyzing?
848 次查看
sufyanalamad1
Hey Daniel,
Really sorry but I'm not at liberty to be sharing the project!
If I attempt flashing before freeRTOS is started, it seems to work. This seemingly confirms my suspicion that the flashing is mainly failing due to the freeRTOS port of taskENTER_CRITICAL() and taskEXIT_CRITICAL().
However for production, it's not feasible that we actually do this. For this reason, I would still like to solve the problem of performing flashing within the freeRTOS context.
Thanks.
