Problem with FreeRTOS, FatFS on FRDM-K22F
搜索替代
682 次查看
vishalgirisagar
Hi All,
   I am trying to get a simple data logger up on FRDM-K22F. I am using KDS and Processor components. I have tried to simplify the problem to the best I can. Below are three scenarios.
1. FatFS with SDcard, HW en, Utility, Timeout, CS1, SPIMaster_Ldd, Generic Time Date.
These are the components.
During Fat1Init, SD1_init(), Below function is called.
void SD1_SPI_WRITE(unsigned char write) {
unsigned char dummy;
SD1_DataReceivedFlag = FALSE;
(void)SM1_ReceiveBlock(SM1_DeviceData, &dummy, sizeof(dummy));
(void)SM1_SendBlock(SM1_DeviceData, &write, sizeof(write));
while(!SD1_DataReceivedFlag){}
After that, I see the interrupt getting triggered. I have put break point in SM1_Interrupt.
Everything in this scenario works fine. I can write, read to SD card.
2. Adding FreeRTOS component to the existing project.
Interrupt does not get triggered at all.
Everything gets screwed up as soon as I add FreeRTOS component.
3. Remove FreeRTOS component.
ISR is called.
Again Everything starts working.
This is weird. I do not have any clue what is happening. Can someone please please help me?
标记 (4)
361 次查看
BlackNight
Interrupts are disabled until you start the operating system. Therefore calling anything like FAT1_Init() which depends on interrupts will not work.
You need to call FAT1_Init from a task context.
I hope this helps,
Erich
362 次查看
BlackNight
I hope this helps,
Erich
361 次查看
vishalgirisagar
Hi Erich,
  Thank you for the answer. Thanks a ton.
