i have to place my own assembled binary code into the
program memory (RAM) e. g. at the address 0x70000.
My code is very small only a few 32 bit arm instructions.
At the end of the code I jump back to the main programm.
(mov pc, r14)
How can I place my binary code at address 0x70000 in RAM.
I will place my 32 bit instructions in a array. The first member of the array must placed at 0x70000,
the second at 0x70004, and so on.
I using the CodeWarrior 10.1
Best Regards
Thomas
Thomas
Presumably you will need to have the small code stored in Flash memory and copy it to RAM when the processor starts.
I assume that simply memcpy((void *)0x70000, code_array, sizeof(code_array)); will be adequate, where code_array[] is your code in flash.
Mark
Hello Marc,
i made an mistake.
I don't want to place my binary code at 0x70000, because its Flash.
I want to place my binary code in RAM Memory. (eg. 0x1fff000-0x1fff800)
I use the default lcf-file.(MK60N512VMD100_flash.lcf)
Do I have to change the Linker Command File ?
I want to have my main code in flash and my selfmade binary code in RAM.
This is what I want:
code_array[0] = 0xE3A00000; // MOV r0, #0
code_array[1] = 0xE2800001; // ADD r0, #1
code_array[2] = 0xE340000A; // CMP r0, #10
code_array[3] = 0x1AFFFFFE;
code_array[4] = 0xE1AEF000; // MOV pc, r14 (return to flash-program)
memcpy((void *)0x1FFF0000, code_array, sizeof(code_array)); // copy binary code in RAM
asm{
MOV r14, pc
MOV pc, #0x1FFF0000
}; //jump to binary code in RAM
