MP3 decoder on CM4
MP3 decoder on CM4
shai_b
Senior Contributor II
Hello Team,
My customer is trying to implement MP3 decoder on our CortexM MCU (as a small addon for this design), could you please advise which is the cheapest and lowest power family recommended for such application?
and please if you can share any example code or guideline it would be highly appreciated.
Thanks in advance
kind regards,
Shai
nxf56274
MKE14, MK22 may be a choice. If you want to do the software decoder in MCU, I am not sure if it is a good ideal. We do not have the related information.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
shai_b
nxf56274‌ Hello,
Thanks for your inputs, but MK22/MKE14 is overkill since the customer looking to use this MCU only for decode mp3, and the extra peripherals such as USB is not needed here.
BTW, I have found a two old application note one is AN11178 based Helix MP3 decoder for LPC1700 you can read more here MP3 Solution for LPC1768
the second is AN10583 based MAD MPEG decoder (libmad) for LPC2000
Could you please advise/guide us on how we can port the Helix MP3 decoder library or MAD decoder to the MK10 family or to other low-cost MCU?
Thanks in advance
KR,
Shai
nxf56274
I found some links for you to refer.
https://community.nxp.com/thread/348143?commentID=524719#comment-524719
K22 Player Solution
https://community.nxp.com/docs/DOC-96452
TIC
