Hi to all,
I try to send a few bytes (up to 4) via SPI interface to an external flash. I have already worked with Kinetis' SPI interface without any troubles. Right now, I'm working with a Kinetis MK26 device. The problem is:
I'm not able to send more than 2 bytes in a row (without a CS toggle). The transfer is interrupted after 2 Bytes, irrespective of what I'm doing!
0. General instructions:
All port, clock and NVIC configurations are finished and work!
1. Initialisation:
void SPI2_init(void) {
/* Enable SPI2 interface master mode and set CS0 inactive high */
SPI2_MCR = 0x00
| SPI_MCR_MSTR_MASK
| SPI_MCR_PCSIS(0x01);
/* Set baud rate / frame size is 8 bit for CS 0 */
SPI2_CTAR0 = 0x00
| SPI_CTAR_FMSZ(0x07)
| SPI_CTAR_BR(0x06);
/* Enable end of queue interrupt */
SPI2_RSER |= SPI_RSER_EOQF_RE_MASK;
2. Send data:
void SPI2_send(void) {
/* Clear transmit FIFO full flag */
SPI2_SR |= SPI_SR_TFFF_MASK;
/* Wait for FIFO space */
while(!(SPI2_SR & SPI_SR_TFFF_MASK));
/* Send first 8 bytes and DON'T let the CS0 go back to inactive state! */
SPI2_PUSHR = 0x00
| SPI_PUSHR_TXDATA(0x33)
| SPI_PUSHR_PCS(1)
| SPI_PUSHR_CTAS(0)
| SPI_PUSHR_CONT_MASK;
/* Send second 8 bytes and DON'T let the CS0 go back to inactive state! */
SPI2_PUSHR = 0x00
| SPI_PUSHR_TXDATA(0x66)
| SPI_PUSHR_PCS(1) //CS0
| SPI_PUSHR_CTAS(0)
/* Send last 8 bytes and LET the CS0 go back to inactive state! */
SPI2_PUSHR = 0x00
| SPI_PUSHR_TXDATA(0x99)
| SPI_PUSHR_CTAS(0)
| SPI_PUSHR_EOQ_MASK; //generate end of queue interrupt
3. Receive / interpret data:
void SPI2_isr(void) {
/* dummy variable */
uint32_t tmp = 0;
/* Get the SPI FIFO values */
tmp |= SPI2_POPR << 14;
tmp |= SPI2_POPR << 6;
tmp |= SPI2_POPR >> 2;
/* Clear receive and transmit FIFO */
SPI2_MCR |= SPI_MCR_CLR_RXF_MASK;
SPI2_MCR |= SPI_MCR_CLR_TXF_MASK;
/* Clear end of queue flag! */
SPI2_SR |= SPI_SR_EOQF_MASK;
4. Function call:
void main(void) {
... //Init all the rest
/* Init SPI2 interface */
SPI2_init();
for(;;) {
delay_ms(10);
SPI2_send();
5. Result:
The result is, that I just transfer the first two bytes! Btw. I mentioned, that the SPI2_isr() is called twice after the function call of SPI2_send()...
Thanks for your help!
Pascal
Solved! Go to Solution.
Hi, Pascal,
Frankly speaking, I am not clear about your question, do you mean that the SPI just transfers two bytes even if you write 4 bytes? I suspect that the FIFO save the bytes but not send out.
I suggest you disable FIFO mode by setting the DIS_TXF and DIS_RXF bits in SPIx_MCR, and suggest you set the TCF_RE to enable interrupt when the byte has been transferred.
Hope it can help you.
XiangJun Rong
Hi, Pascal,
XiangJun Rong
Hi xiangjun,
thanks for your answer! You are completely right with your suggestion of the fault. I just transfer two bytes even if I write 4 bytes. The solution is to DISABLE the FIFO by setting DIS_TXF and DIS_RXF. To generate the interrupt I use the TCIF.
Thanks!
Pascal
