Launch MKW31Z512 Problem
vitaliycheban
Good afternoon. I encountered a problem with CPU startup
The controller is under the following scheme.
Schematic was imported from @frdm-kw41z board schematic
But at startup there are problems such as - lack of generation on quartz, resets twitch with a frequency of 10 kilohertz. The interface SDW works, BUCK MODE also works, there is a voltage of 1.8 and 1.5 volts. Mcu is MKW31Z512
Is anything  missing on this schematic or something wrong?
I cannot launch controller well!
Tags (3)
estephania_mart
I replied you in the internal case you entered with some questions.  :smileyhappy:
Estephania
