Kinetis relocated vector table program counter
1,068件の閲覧回数
ZdenoQC
Hi there,
I'm using a TRK-KEA128 evalboard and I have made a bootloader. Usually on S08/S12 family of microcontroller, I use the reset vector to start my application since this vector is not redirected. I was planning to do the same with the program counter with the Kinetis, but I don't know if a reset will cause the micro to restart directly at the application instead of the bootloader.
Ex:
Boot vector table
/* Interrupt vector table */
__attribute__ ((section (".isr_vector_boot"))) const tVectorTable __vect_table =
{ (uint32_t *) 0x1FFFF400,           // 0x00 0x00000000 -  Initial Stack Pointer
        //        ISR name                         num    address     source
                (typ_ISRfunc) EntryPoint_Boot, // 0x01 0x00000004 -  Initial Program Counter
Appl vector table
__attribute__ ((section (".isr_vector_appl"))) const tVectorTable __vect_table =
{ (uint32_t *) 0x1FFFF400,           // 0x00 0x00004000 -  Initial Stack Pointer
                (typ_ISRfunc) EntryPoint_Appl, // 0x01 0x00004004 -  Initial Program Counter
I will than jump to address written in 0x00004004 when in boot to go to the application and than redirect the vector table.
My question, if I do that, when a reset occur, do the micro will restart in the boot or the appl?
700件の閲覧回数
Jorge_Gonzalez
Hello William Deshaies:
After reset the KEA MCU always takes the entry point from flash address 0x00000004. For your case, after reset the MCU would always jump to EntryPoint_Boot and in the code there could be a decision to stay in bootloader or jump immediately to the application (e.g. by reading an external button).
In the startup of the application make sure to update the SCB_VTOR register to point to the application's vector table.
I hope this helps!
Regards!,
Jorge Gonzalez
701件の閲覧回数
Jorge_Gonzalez
I hope this helps!
Regards!,
Jorge Gonzalez
700件の閲覧回数
vignesh_vb_7
    How do i do that In the startup of the application to update the SCB_VTOR,  Can you give me a code snipet for this?
And if you can give an example code for blinky with changed linker file to be flashed with bootloader, it will be great?
