Kinetis USB audio microphone
1,328 次查看
palmering
There is an example of USB Audio Speaker (audio from PC to uC) using Freescale's USB stack but I wonder, instead, if it is possible to do an USB Audio Microphone (audio from uC to PC) with this library.
If someone knows, please let me know.
Pablo
标签 (2)
标记 (2)
946 次查看
martynhunt
Hi Pablo,
In Freescale's USB stack package, there should also be a USB device app called "audio_generator". This demo sends audio data from the uC device to the host PC, and would be a good place to start developing a USB Microphone application.
Martyn
946 次查看
palmering
Hi Martyn,
Thanks, I had not considered it. It seems that they generate audio from samples in memory (audio_data.c). I'd have to replace this with samples of AD converter. I'm going to test this demo soon.
Best reagrds,
Pablo
946 次查看
palmering
Through Martyn´s help I have been able to find the right example for my needs.
Due to size code limitation in my Codewarrior, I generated a sine wave with a digital oscillator instead of a wave table.
I replaced the "USB_Prepare_Data" function with this:
#define WAV_LENGHT 9
#define A=0.05f
#define M_PI  4.0*ATAN(1)
#define FS  44100.0
#define F0  1000.0
#define W0  2*M_PI*F0/FS
#define K1  1.9797349455598831615890608617794f
float Y1=0.035498579489406697256333580400447f;
float Y2=0;
  Y = a*Y1 - Y2
  K1=2*cos(2*PI*f/FS)
  Y1=A*sin(2*PI*f/FS)
  Y2=0
void USB_Prepare_Data(void)
    uint_8 k;
    float c;
    if (g_cur_mute[0] == 0)
        // copy data to buffer
          for(k=0;k<WAV_LENGHT;k+=3)
              c = (K1*Y1-Y2);
              long2word( (U24*)&wav_buff[k], (long int)(8388608.0*c));
              Y2 = Y1;
              Y1 = c;
    else
          for(k=0;k<WAV_LENGHT;k++,audio_position++)
              wav_buff[k] = 0;
I used 24bit samples and a sampling rate of 44100Hz, so it was necessary to change the usb_descriptor.c.
Attached U24.C and U24.H are only for data conversion.
It ran O.K. in my board.
Next step is add an AD converter...
Enjoy!
