Kinetis USB audio microphone
1,244件の閲覧回数
palmering
There is an example of USB Audio Speaker (audio from PC to uC) using Freescale's USB stack but I wonder, instead, if it is possible to do an USB Audio Microphone (audio from uC to PC) with this library.
If someone knows, please let me know.
Pablo
ラベル(2)
タグ(2)
3 返答(返信)
862件の閲覧回数
martynhunt
Hi Pablo,
In Freescale's USB stack package, there should also be a USB device app called "audio_generator". This demo sends audio data from the uC device to the host PC, and would be a good place to start developing a USB Microphone application.
Martyn
862件の閲覧回数
palmering
Hi Martyn,
Thanks, I had not considered it. It seems that they generate audio from samples in memory (audio_data.c). I'd have to replace this with samples of AD converter. I'm going to test this demo soon.
Best reagrds,
Pablo
862件の閲覧回数
palmering
Through Martyn´s help I have been able to find the right example for my needs.
Due to size code limitation in my Codewarrior, I generated a sine wave with a digital oscillator instead of a wave table.
I replaced the "USB_Prepare_Data" function with this:
#define WAV_LENGHT 9
#define A=0.05f
#define M_PI  4.0*ATAN(1)
#define FS  44100.0
#define F0  1000.0
#define W0  2*M_PI*F0/FS
#define K1  1.9797349455598831615890608617794f
float Y1=0.035498579489406697256333580400447f;
float Y2=0;
  Y = a*Y1 - Y2
  K1=2*cos(2*PI*f/FS)
  Y1=A*sin(2*PI*f/FS)
  Y2=0
void USB_Prepare_Data(void)
    uint_8 k;
    float c;
    if (g_cur_mute[0] == 0)
        // copy data to buffer
          for(k=0;k<WAV_LENGHT;k+=3)
              c = (K1*Y1-Y2);
              long2word( (U24*)&wav_buff[k], (long int)(8388608.0*c));
              Y2 = Y1;
              Y1 = c;
    else
          for(k=0;k<WAV_LENGHT;k++,audio_position++)
              wav_buff[k] = 0;
I used 24bit samples and a sampling rate of 44100Hz, so it was necessary to change the usb_descriptor.c.
Attached U24.C and U24.H are only for data conversion.
It ran O.K. in my board.
Next step is add an AD converter...
Enjoy!
