I need to update the FW for my board on the field.
Can you recommend a bootloader for MK20DX256VLK10 micro among the many possibilities that Freescale offers?
The time to implement the solution is few, this is why a quick fix would help me.
Best Regards
Francesco
Solved! Go to Solution.
Hi Jingjing
I resolved. My board is connected to the host via usb cable.
I ported freedom_bootloader for K64F from FSL_Kinetis_Bootloader_1_2_0
thanks anyway for the reply
Francesco
Hi Francesco Ferraro,
Do you want to use the UART bootloader?
If yes, you can refer to the application note and it's sample code.
The application note is AN2295:
http://cache.nxp.com/files/microcontrollers/doc/app_note/AN2295.pdf?fsrch=1&sr=1&pageNum=1
The according sample code is AN2295SW:
http://cache.nxp.com/files/microcontrollers/doc/app_note/AN2295SW.zip
Wish it helps you!
If you still have question, please let me know!
Jingjing
Hi Jingjing
Francesco
Hi Francesco,
That's very good to hear you solved the question.
If the post answers your question, please click the Correct Answer button. Thank you!
Jingjing
