Ke04 elf file to hex
IlConte
Dear all, for Ke04 microcontroller with codewarrior foe mcu, i need to convert the output elf file to hex or binary file.
How it is possible ?
Stefano
ErichStyger
Senior Contributor V
Hi @IlConte ,
yes, you can do this directly as part of the build process, see
https://mcuoneclipse.com/2012/09/27/s-record-intel-hex-and-binary-files/
I hope this helps,
Erich
