KW35A/36A AoA or phase-based ToF APIs
bfrapple
I see that the KW35A/36A devices support AoA and ToF localization technologies.
https://www.nxp.com/docs/en/brochure/NXP-KW35-infographic.pdf
Is there a demo or API guide that I can use to evaluate these technologies?
antonyuyukov
HI,
Please help
Where I can find more information about AoD and ToF implementation on FRDM-KW36?
Does FRDM-KW36 need to make any hardware changes to test AoD and ToF?
Where I can to download  KW36 ToF GUI  ?
estephania_mart
Sorry but the information mentioned is the only one available , maybe you can check the FRDM-KW36 Minimum BoM Development Board User’s Guide for the minimum BoM hardware or the Hardware Design Considerations for MKW35A/36A/35Z/36Z Bluetooth Low Energy Devices
About the registers you can check the MKW36/35/34 Reference Manual as you will have there the information of the registers and some clock management.
Hope this helps.
I'm not sure which KW36 ToF GUI  you are referring , could you please provide more details ?
Estephania
andreas_karlqvi
Is there any API/registers for AoA antenna switching?
estephania_mart
Sorry for the inconvenience this might cause you, but we do not have any example for what you are looking for yet.
Our current SDK contains APIs to capture IQ, nonetheless, you will need to your own examples with those API's.
The API's  can be found at the following path.
              <installation path>\ middleware\wireless\framework_x.y.z\XCVR\MKW36Z
Estephania
vigneshbalaji
Senior Contributor I
     Can you please provide some API documentation for IQ Method? Please share us the screenshots with information of which functions are used for what
