KW30Z Connectivity CSTACK warning
828件の閲覧回数
lucianfiran
IAR 7.50;  KW40Z_Connectivity_Software_1.0.1 (KSDK_1.3.0)
If enable graphical stack display from Tool Options...
Got some warnings if set some break points
\platform\devices\MKW30Z4\linker\iar\MKW30Z160xxx4_connectivity.icf
if (isdefinedsymbol(__stack_size__)) {
  define symbol __size_cstack__        = __stack_size__;
} else {
  define symbol __size_cstack__        = 512;
if (isdefinedsymbol(__heap_size__)) {
  define symbol __size_heap__          = __heap_size__;
} else {
  define symbol __size_heap__          = 0;
define block CSTACK    with alignment = 8, size = __size_cstack__   { };
define block HEAP      with alignment = 8, size = __size_heap__     { };
Should the stack be increase and how much ?
Should de heap remain 0 (zero) ?
ラベル(2)
700件の閲覧回数
jorge_a_vazquez
Hi Lucian
No, please don't modify heap, Connectivity framework define his own memory manager, refer to the section 3.3. Memory management of the CONNFWKRM.pdf document, as you can see framework provide a non-fragmenting memory allocation solution, where it defines blocks of memorys as:
         _block_size_  32  _number_of_blocks_    6 _eol_  \
         _block_size_  64  _number_of_blocks_    3 _eol_  \
         _block_size_ 128  _number_of_blocks_    3 _eol_‍‍‍
When a new buffer is requested to be allocated, the framework returns the first available partition block of equal or higher size.
Hope this information helps you
Jorge Alcala
701件の閲覧回数
jorge_a_vazquez
Hi Lucian
Jorge Alcala
