KL82Z - JLink doesn't work in STOP mode
次の代わりに検索
371件の閲覧回数
nickbedbury
For measuring low-power current draw, I programmed an application into KL82Z flash that immediately puts the device into STOP, via POWER_SYS_SetMode().  However, now I can't re-program or erase it.
JLink fails to connect with the attached errors.
I've also tried booting the KL82Z into ROM bootloader and running `blhost`, but that doesn't seem to work either.
Is this expected?  Is there any other way to recover the device?
I'm using KSDK 1.3.0 for KL82Z, and have a JLink Base.
305件の閲覧回数
nickbedbury
Well...that was easy.  It seems I didn't put it into ROM bootloader properly like I thought.  After checking that, `blhost` works fine to erase it.
304件の閲覧回数
kerryzhou
Hi Nick Bedbury,
     Thank you for your solutions sharing.
     If you meet the other question in the future, welcome to create the new question post and let us know.
Wish it helps you!
Kerry
306件の閲覧回数
nickbedbury
