KL82Z - JLink doesn't work in STOP mode
684 次查看
nickbedbury
For measuring low-power current draw, I programmed an application into KL82Z flash that immediately puts the device into STOP, via POWER_SYS_SetMode().  However, now I can't re-program or erase it.
JLink fails to connect with the attached errors.
I've also tried booting the KL82Z into ROM bootloader and running `blhost`, but that doesn't seem to work either.
Is this expected?  Is there any other way to recover the device?
I'm using KSDK 1.3.0 for KL82Z, and have a JLink Base.
618 次查看
nickbedbury
Well...that was easy.  It seems I didn't put it into ROM bootloader properly like I thought.  After checking that, `blhost` works fine to erase it.
617 次查看
kerryzhou
Hi Nick Bedbury,
     Thank you for your solutions sharing.
     If you meet the other question in the future, welcome to create the new question post and let us know.
Wish it helps you!
Kerry
619 次查看
nickbedbury
