KL16 flash ROM problem
985 次查看
takashikonno
The flash ROM data of MKL16Z128VFM4 has been rewritten and the program has not started. What are the possible causes?
7 回复数
802 次查看
kerryzhou
Hi Takashi Konno,
    KL16 don't have the ROM, it just has the flash.
    Do you mean you download the code to the KL16 flash, but it doesn't work?
   I suggest you to use the official code, and download it, debug it, to check the details.
  You can download the SDK from this link:
  https://mcuxpresso.nxp.com/en/select
Any updated question, just let me know!
Kerry
802 次查看
takashikonno
Dear Kerry
I checked the operation by writing the program to the flash.
However, there was a problem that the program did not operate when the
power-on startup was repeated afterwards.
It seems that the flash program data has been overwritten and lost.
It will work again by writing to the flash again.
This problem is not reproducible.
T Konno
802 次查看
kerryzhou
Hi T Konno,
   Before you write the flash, please erase that area at first, then program it.
   When you do the flash operation, please disable the global interrupt.
   If you still have problem, you can give me your test project, I will help you to check it.
Kerry
802 次查看
takashikonno
Dear Kelly
    Thank you for your reply.
    We handle your advice.
    Unfortunately we can not send a test program.
    Is there a possibility of hardware rather than software?
    For example, ESD, reset timing, UART timing of the boot loader, etc.
T Konno
802 次查看
kerryzhou
Hi Takashi Konno,
   Do you mean you are using UART flash bootloader?
If yes, you can refer to the KBOOT2.0, KL25 bootloader: www.nxp.com/kboot
 You also can refer to this post for KL26 bootloader:
How to make MKL26Z128 be recognized by KBOOT Flash Tool Utility?
Kerry
802 次查看
takashikonno
Dear Kerry
    Thank you for the information.
    I will continue checking the operation with reference to the
information
T Konno
802 次查看
kerryzhou
OK, after you check it, if you have question, just let me know!
Kerry
