K64 FlexNVM
K64 FlexNVM
1,017 次查看
LArmstrong1985
I tried to port Kinetis KE15 FlexNVM_eeprom example for K64 microcontroller.
I looked that on the code there is this control
#if defined(SIM_FCFG2_PFLSH_MASK)
    if (SIM->FCFG2 & SIM_FCFG2_PFLSH_MASK)
        PRINTF("\r\n Current device doesn't support FlexNVM feature \r\n");
        app_finalize();
#endif
For the KE15, SIM_FCFG2_PFLSH_MASK is not defined instead for K64 is defined on MK64F12.h file.
Is really not supported FlexNVM or this check is not valid for K64 microcontroller?
Thank you very much!
标记 (1)
972 次查看
nxf56274
ke15 supports the flexnvm. But not the all of the k64 support flexnvm. So the ke15 do not need check whether the device supports. The k64 should do. FCFG2 is also different between two device. You can refer the mauual.
TIC
