K60 Watchdog Refresh Issue
2,642件の閲覧回数
kashyapgada
Hello
I have a Kinetis K60 100 Mhz controller whose WDOG I want to use. I have pasted the driver for the
watchdog and main code below.
The problem is when the code is running the wdog never refreshes even though i do. when i am debugging
the same code works properly. I have tried adding delay between consecutive refreshes but it just doesnot
work. Please Help.
void main (void)
  disable_irq(45) ;
  // Dynamic interrupt vector modification whilst those interruts are disabled
  __VECTOR_RAM[61] = (uint32)uart0_isr;  // plug isr into vector table in case not there already
  /* Enable UART 0 interrupts in NVIC */
  enable_irq(45); //UART IRQ = 45
  motorStatusInit();
// initialize uart rxd txd pins
  PORTB_PCR16 = PORT_PCR_MUX(3);
  PORTB_PCR17 = PORT_PCR_MUX(3);
  uart_init (UART0_BASE_PTR, 100000, 9600);
  UART0_C2 |= UART_C2_RIE_MASK ; // Enable Receive Interrupt
  Init_Gpio();
  Hw_Trig_Test(); //  demo the adc/pdb
  gpio_init(PORTB, PTB, 1, OUTPUT); //Buzzer Output
  wdog_init();
  EnableInterrupts ;
  delay_wdog(100);
  while (1) {
  adc_channel0 = result0A; //12
  finalSendData[5]  = ((adc_channel0 >> 8) & 0x00FF); //toSendData1[1]
  finalSendData[6] =  ((adc_channel0) & 0x00FF); //toSendData2[0]
  adc_channel1 = result1A; //10
  finalSendData[3] = ((adc_channel1 >> 8) & 0x00FF); //toSendData0[1]
  finalSendData[4] = ((adc_channel1) & 0x00FF); //toSendData0[0]
  /* Read Motor Status and update finalSendData with motor status and error bytes */
  delay_wdog(30);
  wdog_refresh();
  delay_wdog(30);
  getAllMotorStatus();
  updateStatusSendData(finalSendData);
  if(Modbus_RxCounter >= Modbus_COMMAND_MAX_LENGTH) {
  crcCheck = receiveData((unsigned char *)Modbus_RxBuffer);
  if (crcCheck == 1) {
  sendData(finalSendData);
  Modbus_RxCounter = 0;
  memset((void *)&Modbus_RxBuffer[0], '\0', sizeof(Modbus_RxBuffer)); //reset array
#ifndef  __WDOG_H__
#define  __WDOG_H__
#include <freescale/MK60N512VMD100.h>
#define WDOG_UNLOCK_SEQUENCE_1 0xC520
#define WDOG_UNLOCK_SEQUENCE_2 0xD928
#define WDOG_REFRESH_SEQUENCE_1 0xA602
#define WDOG_REFRESH_SEQUENCE_2 0xB480
void wdog_init(void);
void wdog_refresh(void);
void wdog_enable(void);
void wdog_unlock(void);
void wdog_set_timeout(uint32_t);
void delay_wdog(uint16_t); //Ms second delay required in us
// function prototypes
void wdog_disable(void);
#endif
#include "wdog.h"
#include "common.h"    // Common Kinetis defines
void wdog_init(void){
  wdog_unlock();
  delay_wdog(1);
  WDOG_STCTRLH = WDOG_STCTRLH_DISTESTWDOG_MASK //Disable WDOG Test Mode
  | WDOG_STCTRLH_ALLOWUPDATE_MASK | WDOG_STCTRLH_WDOGEN_MASK | WDOG_STCTRLH_DBGEN_MASK; //Allow WDOG CTRL Ref Update
  WDOG_TOVALH = 0x0000;
  WDOG_WINL = WDOG_WINH = 0;
  WDOG_TOVALL = 0x15ff;
  WDOG_STCTRLH &= ~(WDOG_STCTRLH_ALLOWUPDATE_MASK) ;
void wdog_refresh(void) {
  DisableInterrupts;
  WDOG_REFRESH = WDOG_REFRESH_WDOGREFRESH(WDOG_REFRESH_SEQUENCE_1);
  WDOG_REFRESH = WDOG_REFRESH_WDOGREFRESH(WDOG_REFRESH_SEQUENCE_2);
  delay_wdog(100);
  EnableInterrupts;
void wdog_enable(void){
  delay_wdog(60);
  wdog_unlock();
  delay_wdog(1);
  WDOG_STCTRLH |= WDOG_STCTRLH_WDOGEN_MASK;
  delay_wdog(20);
  /* NOTE: DO NOT SINGLE STEP THROUGH THIS FUNCTION!!! */
  /* There are timing requirements for the execution of the unlock. If
   * you single step through the code you will cause the CPU to reset.
  /* This sequence must execute within 20 clock cycles, so disable
         * interrupts will keep the code atomic and ensure the timing.
        DisableInterrupts;
  /* Write 0xC520 to the unlock register */
  WDOG_UNLOCK = 0xC520;
  /* Followed by 0xD928 to complete the unlock */
  WDOG_UNLOCK = 0xD928;
  /* Re-enable interrupts now that we are done */
        EnableInterrupts;
void wdog_set_timeout(uint32_t time) {
void delay_wdog(uint16_t nCount) {
  uint16_t delay = 0;
  for (delay=0;delay<nCount*10;delay++);
  /* First unlock the watchdog so that we can write to registers */
  wdog_unlock();
  /* Clear the WDOGEN bit to disable the watchdog */
  WDOG_STCTRLH &= ~WDOG_STCTRLH_WDOGEN_MASK;
5 返答(返信)
780件の閲覧回数
Hui_Ma
I check your void wdog_init(void) function with below code:
Which will disable further updates to WDOG write once registers.
The unlock sequence is effective only if ALLOWUPDATE is set.
Then after wdog_init, the following unlock sequence is invalid.
Wish it helps.
780件の閲覧回数
kashyapgada
Does Refreshing Watchdog require Unlock Sequence? I donot think so.
I commented the line you mentioned but that did not help. The watchdog refreshes properly if i debug in step by step mode but if i just leave it running the watchdog times out.
780件の閲覧回数
Hui_Ma
You are right. The [ALLOWUPDATE] bit does not affect the watchdog refresh. Today I do a test based on TWR-K60D100M board with below test code and I could not find the watchdog reset issue happens with checking RCM_SRS0 register. I program the Flash and let it run without debug, if the watchdog reset happen it will light a LED. While, I don't find the led light during the test.
           //unlock the WDOG
      wdog_unlock();
      //enable wdog and use bus clock as counter source
      WDOG_STCTRLH = WDOG_STCTRLH_WDOGEN_MASK | WDOG_STCTRLH_CLKSRC_MASK
                   | WDOG_STCTRLH_ALLOWUPDATE_MASK | WDOG_STCTRLH_IRQRSTEN_MASK;
      //set timer overflow time to TIMEOUT_VALUE_BUS
      WDOG_TOVALH = TIMEOUT_VALUE_BUS >> 16;
      WDOG_TOVALL = TIMEOUT_VALUE_BUS;
      while(1)
          WDOG_REFRESH = 0xA602;
          WDOG_REFRESH = 0xB480;
Light led code in sysinit.c
        PORTA_PCR11 |= PORT_PCR_MUX(0x1);
        GPIOA_PDDR |= (0x1 << 11);
        GPIOA_PDOR |= (0x1 << 11);
        if ((RCM_SRS0 & RCM_SRS0_WDOG_MASK) == 0x20)
            GPIOA_PTOR |= (0x1 << 11);
Could you test it with your board? And if you could get the same result with me?
780件の閲覧回数
kashyapgada
WDOG_STCTRLH_CLKSRC_MASK I had not added to the watchdog init code and from
the example you gave I added i and it worked.
So the problem was with the clock source, i Had previously selected LPO Osc
which i am not sure why did not worked. And Also the alt source selected
now I need to find out what is it.
But Thanks Alot Hui Ma
780件の閲覧回数
kashyapgada
Thanks alot I will surely try that inform you the results.
