K60 FlexCAN
K60 FlexCAN
1,266件の閲覧回数
vasyapupkin
I can not turn on the receiver FIFO (CAN_LDD component)
6 返答(返信)
781件の閲覧回数
vasyapupkin
Hello Vojtech Filip.
I use CW10.4 and TowerKit K60F120M.
PE when choosing ReceiverFIFO says: "ERROR The component doesn't support this setting!"
What are the component settings prohibit enable FIFO?
Or component does not support FIFO?
781件の閲覧回数
vasyapupkin
In reference to the component written:
     Receiver FIFO - Enable/Disable receiver FIFO feature.
        The following items are available only if the group is enabled (the value is "Enabled")
Where to allow this?
781件の閲覧回数
vfilip
this feature is currently supported only for MSCAN device. As workaround you could use "Message buffers" or freeze the code of this component and implement it manually. I have also passed request to support FIFO feature to developers.
We are sorry for inconvenience.
Vojtech Filip
Processor Expert Support Team
781件の閲覧回数
ninestone
I've run into the same issue on a Kinetis device.  I hope this will be supported in the near future.
781件の閲覧回数
vasyapupkin
Thank you for your help. I will implement manually.
781件の閲覧回数
vfilip
could you please provide more details? What version of CW do you use? What MCU, etc.?
The best way would be to post here the ProcessorExpert.pe file from your project and provide info about CW verison that you use.
Vojtech Filip
