K40: How to enter into low power modes?
941件の閲覧回数
BasePointer
I want to measure K40's power consumption at KwikStik board while it is in various low power modes.
I read about AN4503 but the examples given in the datasheet are not compile-able for me.
Where are the example project files for AN4503? (I use KEIL IDE and C)
Thanks.
タグ(3)
654件の閲覧回数
Kan_Li
Hi Mehmet Fide,
For Keil low power mode example, I have ported KINETIS_SC to Keil last year, and I remember it includes a low power mode demo named as "tsi_low_pwr", through it is for TWR-K60/K40/K53, but it should be a good reference for your case, you may download the project from Adding keil support for KINETIS_SC .
Hope that helps,
B.R
Kan
655件の閲覧回数
Kan_Li
Hi Mehmet Fide,
Hope that helps,
B.R
Kan
