Is it possible to connect VREFH to 0V on the Kinetis KE15Z family?
3,352 次查看
MarcoAEE
i'm using a MKE15Z128VLL7 with available VREFH pin. VREFH will be connected to a 4.096V shunt precision reference (LM4040).
I have to create a project that allows the system to be brought to an ultra low power condition. For this reason, when I put the MCU to deep sleep I would like to turn off all peripherals including the shunt precision reference. Essentially there will be a battery supplying the 5V to the MCU VDD pin and shutting down the 5V that goes elsewhere.
From datasheet it shows that the minimum voltage of VREFH is 2.5V, I wonder if for some reason I can damage the MCU if I bring it to 0V.
Datasheet:
Thank you
Marco
标记 (1)
3,342 次查看
Miguel04
Hi @MarcoAEE
It is not recommended to use values different to the operating conditions.
Best Regards, Miguel.
6 回复数
3,335 次查看
bobpaddock
Senior Contributor IV
Removing power from the module effectively puts an unknown impedance on the internal bus. Current levels can go up.
A couple of diodes to drop the voltage lower than 4.096 might work to have the pin having some voltage when the system is powered down. Check that the difference between Vdd and VRefH doesn't get violated.
3,301 次查看
MarcoAEE
It's an interesting solution. But using shunt reference voltage like LM4040 it have relatively high quiescent current even if the voltage is lower than the reference voltage
I'm considering using a nano power reference voltage like REF35 that has a quiescent current below 1uA
Thank you
Marco
3,293 次查看
bobpaddock
I was assuming the 4040 was still having its power removed when in shutdown state.
Obviously needs isolated from the diode idea too.
3,268 次查看
MarcoAEE
Adding the diode in series to the reference voltage makes it meaningless. This is because the quality of the reference is subject to the fall of the diode and therefore not very precise and accurate
Thank you
3,255 次查看
bobpaddock
Obviously. Sadly text is a poor substitution for a schematic.
3,343 次查看
Miguel04
Hi @MarcoAEE
