I am experimenting some problems with my implementation of the TSI using the KSDK (tsi_v4.h/.c). It seems the sensitivity of the capacitive sensors vary with the input voltage and I am thinking of using the NXP Touch Software to check if that library solves my problems.
Solved! Go to Solution.
After some research I see that the NXP Touch Library 2.0.0 is not compatible with KL26 despite the manual reference (NT20RM) it indeed states it is. The reason is that the library only implements the management of the TSI v5.
So here comes another question, will NXP Touch Library be compatible with KL Series in a near future?
There has no any plan that Touch Library will support the KL Series. Sorry.
