In K10 microcontroller how can we get a real time delay like delayms(100) or delayus(100) for 100 ms and 100 us delay?
868 次查看
psjhawer
Hi All,
I'm using an MK10DX128VLH5 IC in my project. I want to give a delay of exactly 3 secs in between 2 operations. Is there an inbuilt function or something that can give me this exact delay??.
Meanwhile if u guys can help me with the amount of delay the followingfunction gives when run, it would help me solve the issue more easier. The following code is already used in an existing code which i need to change for an upgraded product.
Delay_t(20000);
void Delay_t(unsigned int i){
  int k;
while(i--){
    for(k=0;k<10;k++){
  asm ("NOP");
The CPU Configuration is as follows:
Please help ASAP. Plz let me know if any other information is required..
Thanks in advance,
Prafful
标记 (3)
681 次查看
santiago_gonzal
In embedded projects usually you don't block the MCU to wait for such big amounts of time. Instead you can use a timer to get notified via an interrupt after the time has passed.
This tutorial will help you:
http://mcuoneclipse.com/2012/08/13/tutorial-timer-led-with-processor-expert-for-kinetis/
Santiago
681 次查看
jeremyzhou
Hi Prafful,
Santiago illustrated one way to get precise delay, and I'd like to suggest that you can also use the systick timer to implement precise delay.
You could check the detail description of systick timer through the thread as follow.
Where is detail description for Systick for KL?
Ping
682 次查看
santiago_gonzal
Santiago
681 次查看
psjhawer
Thanks for your reply santiago.gonzalez The timer inturrupt was very helpful and made my day. :smileyhappy: The tutorial u suggested was also very helpful. Thanks once again..
Prafful
:smileyhappy::smileygrin::smileyhappy:
