I have a fairly simple project, which I am looking to implement with the FRDM-KL25Z board. The main requirements are:
It is a low volume commercial application. Although it is fairly simple, I would like highly reliable and supportable firmware. Should I use something like Keil MDK-Lite, or use mbed?
已解决! 转到解答。
Hi, Air
I think it is better to use IAR or CodeWarrior as IDE for your project development. You can find many example code for your reference from Freescale website. If you want to use real time operation system, I think you can use MQX for your application.
Hope my reply can help you.
Best Regards
Paul
Hi, Air
Best Regards
Paul
