I2C IICIF bit flag not activated on transfer
次の代わりに検索
1,407件の閲覧回数
luisluna
Does anybody of you have happen that after reading some registers in a slave device the IICIF bit flag does not get activated after sendind the register address to the slave device?
This is happening after reading successfully a register and attempting to send the next register address with the same slave address. I think that the I2C module is properly configured because I can communicate with the accelerometer in the board, but when I try other devices I get stuck waiting to for the register address to be send.
This is my init code for the I2C
void init_I2C(void)
    SIM_SCGC4 |= SIM_SCGC4_I2C0_MASK;   // Turn on clock to I2C0 module
    BW_PORT_PCRn_MUX(PORTE_BASE,24u,kPortMuxAlt5);  // Configure pin functionality for I2C0
    BW_PORT_PCRn_MUX(PORTE_BASE,25u,kPortMuxAlt5);
    I2C0_F  = 0x17;                     // SLC divider is 128 for 50MHz clock (I2C works in ~390KHz).
    I2C0_C1 = I2C_C1_IICEN_MASK;        // enable IIC
This is how I read the registers:
unsigned char ReadRegister(unsigned char u8RegisterAddress)
unsigned char result;
  /* Send Slave Address */
  IIC_StartTransmission(SlaveID,MWSR);
  i2c_Wait();
  /* Write Register Address */
  I2C0_D = u8RegisterAddress;
  i2c_Wait();
  /* Do a repeated start */
  I2C0_C1 |= I2C_C1_RSTA_MASK;
  I2C0_D = (OV7740_I2C_ADDRESS << 1) | 0x01; //read address
  i2c_Wait();
  /* Put in Rx Mode */
  I2C0_C1 &= (~I2C_C1_TX_MASK);
  /* Turn off ACK since this is second to last byte being read*/
  I2C0_C1 |= I2C_C1_TXAK_MASK;
  /* Dummy read */
  result = I2C0_D ;
  i2c_Wait();
  /* Send stop since about to read last byte */
  i2c_Stop();
  /* Read byte */
  result = I2C0_D ;
  return result;
#define i2c_Start()            I2C0_C1 |= I2C_C1_TX_MASK;\
                                         I2C0_C1 |= I2C_C1_MST_MASK
#define i2c_Stop()             I2C0_C1 &= ~I2C_C1_MST_MASK;\
                                          I2C0_C1 &= ~I2C_C1_TX_MASK
This is how I wait fo the byte to be transmited and were my code get stuck because the IICIF bit never gets active.
#define i2c_wait()   while((I2C0_S & I2C_S_IICIF_MASK)==0) {} \
                               I2C0_S |= I2C_S_IICIF_MASK;
746件の閲覧回数
mjbcswitzerland
Specialist V
Luis
Are you sure that the first I2C message transmission has completed (stop condition completed) before sending a second message to a different device?
Try waiting for the bus to become idle before sending the second message - eg.
while (I2C0_S & IIC_IBB) {}
Mark
5 返答(返信)
746件の閲覧回数
luisluna
Thanks Mark,
Seems like this was causing the issue.
746件の閲覧回数
jonathanlee
Hi,Luis,
I have the same question as yours, would you please tell me where you put this "while (I2C0_S & IIC_IBB) {}" to solve the problem?
Best Regards!
746件の閲覧回数
luisluna
Hi Li,
It was needed to be added after the read of the data, like:
  i2c_Wait();
  i2c_Wait();
  i2c_Wait();
  /* Dummy read */
  result = I2C0_D ;
  i2c_Wait();
  i2c_Stop();
  /* Read byte */
  result = I2C0_D ;
/* Wait for the bus to be free */
  while (I2C0_S & I2C_S_BUSY_MASK)
  return result;
where  I2C_S_BUSY_MASK is  0x20u
Hope this helps :smileysilly:
746件の閲覧回数
jonathanlee
Hi,Luis,
Thanks for your reply.
It helps,my program works well now. I add   while (I2C0_S & I2C_S_BUSY_MASK), and send nack.
Thanks again.
Best Regards!
Li
747件の閲覧回数
mjbcswitzerland
Specialist V
Luis
Mark
