How to use NVM [internal eeprom] write api in KW40z ?
Search instead for
chandramohanc
I am trying to use NVM [internal eeprom] read / write APIs but do not know available EEPROM size and start address
I don't see comments for startAddress and endAddress for the NVM read/write APIs for FRDM KW40Z boards
Please explain how to find nvmDestinationAddress parameter's range.
void App_NvmWrite
    uint32_t nvmDestinationAddress,
    void*    pvRamSource,
    uint32_t cDataSize
thanks, Chandra..
chandramohanc
Hi all,
I found the solution and verified it,
In AppMain.c you can find below 2 functions to do Flash operations
void App_NvmWrite (int32_t nvmDestinationAddress,  void* pvRamSource, uint32_t cDataSize);
void App_NvmRead(uint32_t nvmDestinationAddress, void*    pvRamSource, uint32_t cDataSize);
Its destination address is defined in linker script, and its value is initialized to gNvmStartAddress_c in ApplMain.c at runtime as below
#if mAppUseNvm_d
        /* Initialize NV module */
        NV_Init();
        /* NV_STORAGE_END_ADDRESS from linker file is used as NV Start Address */
        gNvmStartAddress_c = (uint32_t)((uint8_t*)NV_STORAGE_END_ADDRESS);
#endif
thanks, Chanda..
chandramohanc
Hi all,
#if mAppUseNvm_d
        NV_Init();
#endif
thanks, Chanda..
jorge_a_vazquez
Hi Chandra
About the API that you mention, it is:
void App_NvmWrite
    void*    pvRamSource,
    uint32_t cDataSize
#if mAppUseNvm_d
    NV_FlashProgramUnaligned(&gFlashConfig, nvmDestinationAddress, cDataSize, pvRamSource, gFlashLaunchCommand);
#endif
And aas you can see here, it is using the NV_FlashProgramUnaligned function. This function uses the global variable gFlashConfig, which is defined as:
FLASH_SSD_CONFIG gFlashConfig =
    FTFx_REG_BASE,          /* FTFx control register base (0x40020000) */
    P_FLASH_BASE,           /* base address of PFlash block (0x00000000)*/
    P_FLASH_SIZE,           /* size of PFlash block (65536*2+16384*2) */
    FLEXNVM_BASE,           /* base address of DFlash block  */
    0,                      /* size of DFlash block */
    EERAM_BASE,             /* base address of EERAM block */
    0,                      /* size of EEE block */
    DEBUGENABLE,            /* background debug mode enable bit */
    NULL_CALLBACK           /* pointer to callback function */
So, they basically are defined characteristics of internal flash, the device contains 2 program flash blocks (one 128Kbytes, one 32Kbytes).
Hope this information helps you
Jorge Alcala
chandramohanc
Hi Jorge,
   Thank you for your inputs, i found it, it is in ApplMain.c
#if mAppUseNvm_d
        NV_Init();
#endif
thanks, Chandra..
