How to turn off USB block.
469 次查看
CCandido
Need to turn off usb complete, without unplugging cable, and without resetting the processor.
I need to use same usb cable for two usb processor.
I made a few attempts but when you hang up, you will not call later.
I need to turn it off and on.
I have an application on (PC) that chooses and controls which device to use.
Processor: MK20
USB Stack 4.1.1 (cdc)
IDE: KDS- V3
Carlos.
标签 (2)
320 次查看
estephania_mart
 Dear Carlos Candido,
One of the things I would like to mention it’s the fact that in the USB communication the host it’s the one in charge of managing the devices and descriptors; for that reason, the device cannot perform a detach by itself.
The host it’s who can send a BUS RESET command to the reset of the end devices; in any case of a disconnection or reset the re-enumeration can’t be left behind, it will always need to re-enumerate the device.
One approach it’s to add a transistor in the VBUS connection, as the D+ / D- lines resistors are hung up to them, this transistor will be controlled by a GPIO acting as a switch by doing this the host will acknowledge this as a detach.
Estephania
320 次查看
CCandido
Hi, Estephania
I had not thought of it that way,
I'm going to take a test.
thanks,
Carlos.
